I brought almost all the stuff. 600 feet of nylon rope, socks, tape, scarfs, a magic wand, pin wheel and feathers.
I started topping first and figured to just break in and ease the tension with a bikini harness. Which I wanted to do because I could always use it for later
After showing some knots I basically explained alright, fun time. I took a scarf, blindfolded her and then proceeded to tie her hands behind her back. When I was done I then took a small piece of rope and leashed it to the harness to let her feel some force back if she decided to move her hands. I helped her on to the bed and then proceeded to tie her legs and thighs. During all of this I did want to gag her, but I wanted to make sure nothing was to tight or pinching on my part. I mean this was the first time finally rigging someone with my imagination. So I pulled the ankles up, fed them through the harness and she was nicely put in a hogtie which I left her some time to feel everything out and experience.
After some time I decided it was time for some vibe fun. I undid the hogtie, ankles and legs. Then I flipped her over and Frogtied each leg together. She didn’t expect what was about to happen next. I had my nice dress sock curled up in a nice ball. I immediately pinched her nose and waited….waited and finally when the gasp came I shoved the sock in her mouth and use some black duct tape to cover it. About 4 even strips from under the nose finishing tk just under the chin. Making sure it was real secure. She liked it but as she laughed underneath the gag. Neither of us took any of this serious we had a great time and laughed at random remarks.
From that point on all she could do was hear me flip the vibrator on and go to town. Let me tell you, my first time with her and every women is different. She is endurance insanity. I could get her to squirm, wiggle and moan a lot. To the point I made it even more hot for her when I started leaning on the legs Frogtied spread apart so she could get away from the magic wand. It was a good 45 minutes of straight vibing and while she did minorly get off it was never a release. So I was a little disappointed. I ungagged her, confirmed everything was ok. She then tells me that even she can never get herself to release. So at that point I decided to stop with the vibrator as my wrist was so dead from using it, the pressure and motions to get a finish.
So at that point I undid the frogtie and her hands, let her stretch a little. The blindfold and harness stayed on. While was stretching the muscles I decided to pull over a sit down bench in the room and have her lay her back on it. Feet flat on both sides and hands dangling off the end.
It was a long N shaped bench so there was a big gap underneath that I could work with. So I can to make an insanely long leg cuff from one ankle to the next. Larx headed the ankles underneath the bench and then became cuffing wrapping the ropes over and over. It was a good 3-4 foot cuff so I had to expand the rope a bit halfway but in the end both ankles on the sides of the bench were connected to each other and very secured. She could move it forward and back because I didn’t restrict the legs but she couldn’t get them past the bench due to the cuff running underneath. From here I single column tied each wrist dangling on each side to the ankles and then put a rope across her chest to keep her body a bit more pinned to the bench. I did notice she started picking at the ropes a bit. So I took the duct taped and wrapped her fingers, but I also secured them to the single column lines going to the ankles. This way even if she got a little sweaty the rope was going to hold the tape. So now she can move whatever’s dangling but nothing can get undone. She tried hard to remove the tape from her hands but it tightly secured along the column tied on each side made it hard to break the tape. At this point I gagged her again with a sock and tape. But I remember her saying before it came off a bit easy if she pushed if with her tongue. So while she was trying to remove the gag I grabbed some vet wrap and went around the mouth, the eyes which was blindfolded and kept alternating each wrap. Me having tested vet wrap knows the more you wrap the more tight it gets. So I tried to do it securely but not super tight to hurt the jaw in a long session. Sure enough, the gag was now pinned back against the mouth due to the vet wrap and she couldn’t lick the tape off. At this point I took the pin wheel and start rubbing the undersides of her feet. It was great to watch her squirm and try to hide the soles but when she hid one, the other became available due to the cuff and length. So back and forth we tickled with the pin wheel on each foot. Eventually after a good amount of time I realized that 3 hours had already gone by in a blip and I was getting hungry. I asked her if she was hungry….she groaned yes. So I released her from her binds and we went and got dinner.
End of me topping, I’ll post my experience and the rest later today sometime.
I do have photos, but I’m not ready to post them yet.
